As a tangent of this thread... http://www.candlepowerforums.com/vb/showthread.php?333486-RRT-0-AA-extender-max-lumen-and-runtime
I've done some very crude measurements for current draw of the following lights:
RRT-0 XML, R5, S2
V10R Ti (R5), XML
Preon 2 High CRI (just for kicks)
Again note that although it may appear there is a modicum of control, this really is a high level informational post. You CANNOT simply take battery capacity and divide by the current draw to obtain runtime numbers, though you can make some pretty neat inferences. The point is by measuring them at the same time using the same resources, the numbers can be compared somewhat.
All measured values in mA rounded to the nearest integer. Measured five times using five different points, discarding max/min, then averaged.
RRT-0 XML, R5, S2
V10R Ti (R5), XML
