Re: AW RCR123 in a Surefire U-2?
It depends on which model of SF U2 (the newer Seoul led version, or the older Luxeon V version)
I believe that the older Lux V version will not work with 2x RCR123, and will be damaged.
It will run nicely on a single 17670, or if you lucky enough to have a really old plastic sleeved model, an 18650.
I have no experience with the newer model.
I have an old Lux V model, with the plastic sleeve removed.
I think the only time it has run primary cells is the first 2 that came in it, since then it has run on 17670 and now 18650, all 6 levels work, although the runtime on level 6 with 17670 is much shorter, around 30-40 mins (still leaves you another couple of hours at the lower levels)
The U2 is an awesome light, I love mine, and still use it regularly, I would like to get more power out of it though (maybe a nice neutral tinted MCE mod, or some othe suitable led is in the future).
