You do this for RCRs? About what voltage does that leave them with, and I assume it does not trip the protection circuit?
I've also been doing something similar for NiMh - when I can't tell the difference between Max and High, I recharge - but I don't know if this is a safe practice for Li-ions... Also wonder if using a low voltage head 0.9-4.2, vs the high 3-9v, or even running single vs double cells makes a difference...
yeah, NiMH's are more tolerant to practically being totally drained. Sometimes it would be better to have them drained before charging them up again to ensure the cells are in good health and can keep a charge longer. But since switching to eneloops, those are things of the past for me! haha
But i do have the tendency of still "drain-charging" my eneloops, force of habit i guess. haha!
For Lithium Ions since they should have a significant amount of voltage left (at least 1volt i heard) to be able to charge properly, i guess having to drain it down to almost empty may not be advisable. I've zeroed one accidentally, and it definitely refused to charge anymore.
Oh yeah, there is indeed a difference, if you run a high voltage head with a single 3.7 volt cell, its not as bright as running it off two cells. As such, the lower voltage head gives much better output with a single 3.7volt cell.
Heck, this is why my EDC is a Quark AA with a 14500 cell.
