Went to walMart yesterday, and as usual, was cruising through the sporting goods/camping department looking for new lights. Sure enough, I spotted a new offering from Energizer. It's a single LED light that runs on 3 LR44 button cells that's worn around the neck on a break-away lanyard. The "twist" to this light is that it has a tail switch that you pull on instead of push to turn the light on! You turn it on like you would a light bulb that has a pull string switch...pretty nifty! It's named after Energizer's new LED/CCFT light...it's also called a Trail Finder LED Light. On fresh batteries it's as bright as my Ultra-G, but on 3 button cells I doubt that that will last very long. Energizer claims 12 hour run-time on 3 button cells (provided), but after the first hour I'd venture to say that brightness will be RAPIDLY diminishing. All in all, for around 5 bucks it seems to be a pretty good deal! The beam has some weird artifacts as a result of the dome shaped lens covering the LED, but for a utility light that hangs around your neck and is turned on by a simple tug on the light itself, it's pretty spiffy for the price! I couldn't find it on Energizer's website, but my WalMart had LOTS of 'em...so go spend 5 bucks and pick one up! It's pretty handy, and appears to be fairly weather resistant!
PJD
PJD
