O-Ring for a Surefire C2 to fill in gap at Bezel after installing Malkoff M61 ?
Talldog77656
After installing a Malkoff M61 in my Surefire C2, the Bezel won't screw down all the way which leaves about a 1/16" gap. Does anyone sell a gasket or o-ring to take up this space?
Thanks
enomosiki
Apparently, the tiny gap between the head and body upon installing a Malkoff is a known issue but not a problem.
If it bothers you, you can file the top of the drop-in with a fine file to get rid of it.
ElectronGuru
Oregon
The flat O ring found under the pyrex lens that came with the C2 bezel is perfect.
Just replace it with thicker o ring when replacing the lens and you're good to go.
