Hello guys,
Pls look at this litte guy,
Olight S10
Key features
1. Utilizing the newest Cree XM-L LED, the highest output reaches 320 lumens;
2. Three adjustable brightness levels, can be changed "low-middle-high–middle–low" in cycle, the moonlight mode can be accessed directly when the flashlight is off; double click the on/off button to activate strobe mode;
3. Equipped with auto memory function and a side switch, the total length is only 70.5mm;
4. With strong magnet at the tail, the flashlight can be attached vertically on any iron surface;
5. With a two-direction invertible pocket clip, easy and reliable for use;
6. Stainless steel head ring, can bear higher impaction;
7. Flat tail cap allows convenient tail standing;
8. High efficiency constant current drive circuit; perfectly compatible with CR123A and RCR123 battery;
9. Battery reverse polarity protection.
my impressions,
+ excellent build quality, nice anodizing, smooth threads
+ dust free lens and reflector
+ perfect beam quality (thanks to LOP reflector and perfectly centered led)
+ all modes are ok, no pwm flickering
+ side switch, very comfortable
+ SS bezel ring
+ separated moonlight mode
other comments,
short runtime for me in high mode with RCR battery, but ok this is an CR123 light...I think Olight S20 (18650) coming soon..
would be better two tail cap, magnetic and normal tail cap without magnet
Now, here is my pictures, beamshots coming soon. Please click pictures if you need higher res
beamshots (click side by side pic for higher res)
S10 vs Sunwayman C20C (280lm)
S10 vs Nitecore SENS CR (RCR123)
Olight S10
Key features
my impressions,
+ SS bezel ring
other comments,
