They are 7$ so these little lights are clearly out of the running as bulk buy fauxtons, but they are also quite a bit cheaper than Photons and in some ways better.
I bought a handful of them as gifts and I've been testing one for the last three weeks.
10hours on high, 22hours on low -according to the box.
The UI is good, basic but very user friendly.
Switching from demo mode (high, momentary only) to it's primary UI would happen automatically if a person used the light for any length of time without ever reading the directions.
I think that this is a good thing.
In demo mode the light will deliver max when the light is squeezed and turn off as soon as pressure is released.
Standard mode is activated by simply squeezing the light on for over 15 seconds.
Once in standard mode the light will come on in high (6 lumens) and stay on... But it will auto off in 4 minutes with a flash warning first.
Two squeezes from off turns the light on in low (1 lumen) - there is no auto off function in low.
Three squeezes from off turns the light on in a flash mode of about 4 flashes per second that appear to my eye to be the low power setting and a 25-50% duty cycle, so I'd expect the flash to last twice as long as low or better as a guess. This should be good for clipping one to a person or object and finding it again a day or two later.
Switching back to momentary/high only demo mode is accomplished by squeezing three times from off (flash mode) and Immediately holding the button down for more than 5 seconds... It is easy as can be once you know how, basically " from off: 4 clicks and hold".
I was not initially impressed with the clip and my first thought was to replace it with something sturdier, maybe paracord sheathing, but I've kept it clipped to the neck of my shirt or transferred out to various things for the last three weeks and the clip works very well, convenient and secure.
The light itself is a flat, rounded diamond shape and there is nothing to catch or stress the clip, which does a good job of staying clipped on and a good job of coming off easily with one hand when desired.
I've come to the conclusion that the clip design is a real strong point of this light.
Weight with clip and batteries (two 2016 coin cells) is .37 oz.
I'm going to start carrying a few of these daily as semi disposable lights for back up, lending, giving, or marking a location, etc.
