LED-FX
This post just came up on sci.engr.lighting
The original post is indent quoted with my reply interspersed:
>>>Peter Lowrie" <[email protected]> wrote in message
news:[email protected]...
> 15 November 2003.
> Announcement:
> Light Emitting Diode (LED) Intensification Breakthrough in New Zealand
> laboratory.
> Using ultra-small electronic componentry to intensify (make brighter)the
> ubiquitous LED, the LED output can be increased by up to four times
without
> blowing them up as would be expected when you shove too much voltage into
> them.
Er, LEDs are current driven.....
> The Free Electron laboratory technicians in Lower Hutt, North Island,
> New Zealand have developed a device to intensify LED's by overpowering and
> cooling LED's
T1 , T1 3/4, LStar, Spider, SMD what kind of LED exactly?
How does the LED mount to the device to acheive this cooling?
>to make an otherwise mediocre LED shine furiously bright.
> Given the headlong rush to more Lumens per Watt and the wide range of
> applications that LED's lend themselves to, it is surprising that such
> an add-on component has not, before today, been developed.
Because using any form of active cooling loses any efficency benefits is
probably why...
>The LED
> Accelerator brings a solution to bear upon the problem of otherwise poor
LED
> luminosity performance. At an increasing rate LED's are being used in
> industry, transport, home and personal lighting, security, communications,
> toys and consumer electronics, the future is bright then, for a company
> that will manufacture and distribute the LED Accelerator.
> In the next few days it is expected that rights to the device will be
> auctioned by eBay and at other auction sites in Europe, and Australasia.
> http://www.geocities.com/ledaccelerator
> This press release was provided by:
> Peter E. Lowrie.
> Chairman,
> Free Electron.
> High St,
> Lower Hutt, 6009.
> New Zealand.
> ++64-4-9766712
Honestly would like to see good LED products given wider publicity,my living
depends on it.
However, obvious snake oil salesmen and kooks should be shunned and exposed
as speedily and thoroughly as possible.
Clearly this character belongs in this category, lines such as this expose
him as a charlatan:
"The Device interconnects a nominal 9 Volt DC supply to nominal 5 Volt Light
Emitting Diode Arrays."
Perhaps he sells previously unknown to physics 5V LED arrays.
Another `power saving` con.
Adam
If its for real, I have no problem apologising.Regretably I dont think it is.Any comments from the panel?
Adam
> 15 November 2003.
> Announcement:
> laboratory.
without
> them.
> cooling LED's
probably why...
>The LED
LED
> Peter E. Lowrie.
> Chairman,
> Free Electron.
> High St,
> Lower Hutt, 6009.
> New Zealand.
> ++64-4-9766712
depends on it.
him as a charlatan:
Adam
Adam
