SureFire compatible tip diffusers for camping.
ledmitter_nli
What are you guys using for your C2's and 6p's? Will the Fenix diffusers fit?
JCD
Anything designed for a 1.25 inch bezel should work okay.
cerbie
What is there like that, except for wands, though? I haven't seen a F04 equivalent item for 1.25", as an example.
gravelmonkey
UK
Like a lantern style of diffuser or a flip-up/down ?lens? kind of diffuser? I've got a Xeno TW02 'wand' diffuser for my 6P, works pretty well. My only complaint is that the material is thicker at the end (I assume so it's strong enough to use the bezel wrench) so you end up with a slightly dimmer circle- bit of a pain if you hang it above a table etc..
Let us know how you get on with the Fenix diffuser!
cerbie
I found the SpiderFire Soft Beam Light Filter. Nowhere that I can find in the U.S. selling it, so I may have to get it from China or the U.K..
LowFlux
I like the Xeno TW02, I picked one up over the holidays along with a G10v2. It fits just fine on 6P, C2, and Z2.
My only complaint about the TW02 is that it emits a cool blue color...even when using a neutral-tinted LED.
