PlayboyJoeShmoe
On an afore mentioned junket to Frys, I looked at lots of stuff. Checked out 4000 and 2100 ??? (BRAIN less than Perfect) LED lights, and a fairly wide array of Pelican stuff.
Was going to get a 3C Super, but for a few pennys less I got this 4AA with batteries (Energizer).
Was still bright outside so couldn't tell much until later. Inside my cab I could tell that there wasn't a perfect beam, still in shining it out at signs and stuff it proved to be quite a useful beam.
The switch is very simple in design. However it doesn't use as well as a slide or push button. Holding it in such a manner as to use the thumb on it is the way for me. I couldn't manipulate it well with my first finger.
In comparing it to several other lights, namely 4AA stuff... It is tighter and therefore brighter at around 20 feet than either Rayovac Prodigy 4AA (with a KPR103) or TEC 40 (with KPR103), however both other lights have a more utilitarian beam and the TEC 40 is just about perfect!
Let's see, what else? Well I wonder why it's called Stealth Lite. It's at least TWICE the size of the UK 4AA AS2 (and the UK is easier to use too!)
Maybe I'll put the Dorcy LED Bulb in it, and some Liths for emergency use.
