papershredder
- Joined
- May 31, 2013
- Messages
- 132
See this new thread with a HOWTO step-by-step and more photos:
http://www.candlepowerforums.com/vb/...-and-beamshots
Well, I was fooling around in the closet the other day with some cheap grocery store incandescents and I decided that the color was quite pleasing. So, I modded my Preon P2 from an XP-G2 cool white to XP-G2 2900K warm white. This is about the same color as incandescent bulbs. I understand that foursevens had some limited run lights similar or the same as this, but I was not able to find any in stock. Plus I already had the cool white P2.
From the left, Preon P2 w/ 2900K, Zebralight SC52w (It's not green, that's just the white balance on my phone camera,) SB Flashlights / L3 Illumination L10 cool white.
I'm kind of regretting picturing the SC52w, as it's not showing up well, but I want to have something in the middle as far as color goes. Oh well. :shrug:
From the left: cheap grocery store incandescent, Preon P2 with 2900K emitter, cheap grocery store incandescent.
As far as the actual work to mod it goes, I used retaining ring pliars to open the light. The PCB where the battery positive terminal touches has two holes. I put the pliers in there and unscrewed the "pill" without trouble at all.
The lens and reflector could also be removed by tipping them out at that point.
The LED was soldered onto a PCB with a plastic retaining and centering ring squished into the pill. After removing the retaining/centering bit, I was able to desolder the leads and remove the LED on its PCB.
I reflow soldered a bare LED onto a new PCB of similar dimensions, applied new thermal paste, soldered the power leads back on, and reinstalled the retaining/centering plastic part.
The work with the flashlight was pretty quick. I probably spent the most time soldering the leads back onto the new PCB. This Preon P2 is pretty friendly if you want to change the emitter. Thanks Foursevens!
Tools needed were a soldering iron, a hot air reflow station, retaining ring pliars, solder, flux, some isopropyl alcohol, paper towels, a haemostat for holding the power leads while soldering, and normal pliers to get that retaining/centering ring out.
I think I'll pick up another head or full light and put a ~3600K led in there. That's about midway from incandescent to what's typical for "neutral white."
