Few years ago this forum helped me to choose EDC flashlight. It was Itp A1 SS. Did its job very well.... yet it died (probably used it too much on high mode).
The SS case is too good to throw away, so decided to get it back to live. Short modlist:
And some photos. Notice how thin original heat sink is.
I made heat sink a bit too long. So no there is a small gap when the flashlight is tightened. O ring helps to hide it. I'll make some nightshots later. Pretty happy with light output from this pocket rocket.
Now to the problems. Circuit board has negative contact on both sides of the pcb. And I noticed it only after soldering everything Flashlight was always on no matter how much tightened (or not tightened at all) it is. I managed to isolate the negative contact from the heat sink (with a thin layer of cellophane) . Now it turns on somewhere at the middle of tightening. When I tighten it all the way it goes off again. Any ideas what could be wrong?
- Cyan 18mm gtd O-ring. Planned to use it for sealing the glass. But 18mm appeared to be not enough.
- 18mm AR coated glass lens. Cracked the original one trying to disassemble the flashlight.
- Noctigon XP16 MCPCB & CREE XP-G2 R5 3C LED
- Nanjg 101-AK-A1 circuit board (3 modes)
- Custom copper heat sink.
