Hello All,
I have been a member for a couple months, read what you good folks have to offer often. This is my first post because I'm not smart enough to contribute intelligently, I still have much to learn. I do have a couple questions that I would appreciate some guidance on if convenient:
1) I just purchased the D25C. I had read that if a 4.2V LI-Ion battery was used it could be driven to 700 lumen output. I purchased the Eagletac Li-Ion 16340 RCR123A battery to go with it. I charged the battery using a Nitecore 4 slot charger that claims 4.2 volts output. After installing the battery I did not experience the two mode function, one being low, the other being 700 lumen out. Is this because I failed to get enough charge in the battery or because even though I purchased the original D25C, it came upgraded with the next gen LED? If the newer gen still has the 700 lumen function, what battery / charger combination should I be looking at for the higher output?
2) I have a 1980's vintage 6D cell Maglite that I am looking to modernize to LED. What would you folks recommend for an LED modification to make this light a long distance thrower. I have an Olight SR90 and don't expect the Maglite to throw further, but would like a similar beam pattern with as much throw as the old light will allow.
Thanks in advance.
Thanks in advance.
