chrissybabe
- Joined
- Nov 22, 2013
- Messages
- 6
I have 5 helmets and lights for new cavers. These have previously used a variety of Petzl lights and I want to move on to LED. Fortunately I think I have found a source of drop in lights that will fit in either of my old housings (2 x Petzl Zoom plus 3 other Petzls). I have to remove all the Petzl switching mechanism but thats not a big deal until although I stuill need a source of switches. The Petzl Zoom has a flat area on the top of the light where the spare bulb goes. I can shave of the bulb mounting plastic and mount a switch on the top as there appears to be a useful amount of room. The other 3 lights (can't remember the Petzl model) happen to have a similar position on the mounting bracket I can use. So needs to be smallish and preferably waterproof (silicone round the rear of the wiring as long as the activation side is waterproof).
The dropins are 3 mode so also need to be the clicky type.
Does anyone have a source for something like this ?
For anybody else who may be interested the DX model number for the Petzl Zoom is 58481.
I think I may have to remove a small trim around the edge for this to fit.
The other Petzl fitting is smaller than the Zoom, has a red body with a black zoom ring. I haven't decided on what dropin to use here but it will be a 26.5mm The Petzl reflector itself appears to be 32mm. . I plan on cutting a hole in the existing Petzl reflector and gluing the dropin inside the hole. This also looks like it will work well.
Note that I haven't done the conversion yet as waiting to solve the switch problem first.
