GuyZero
Ok, so many of you read my subject and thought, "Why would this idiot want to take a simple, reliable, usefull flashlight like the Arc AAA and make it more complicated then it needs to be?"
Just hear me out...
The Arc-AAA already has a standard brightness mode and a moon-mode, why not offer a third Super-Bright mode to answer to the Photon Microlights being brighter (initially) then the Arc-AAA? (Maybe someone has suggested this already - sorry if it's you).
You could design the head so that screwing it in most of the way turns it on like normal, screwing it down a little tighter activates a micro pressure switch in the head that triggers a brighter mode (but with a shorter run time).
Then you end up with a single AAA flashlight that is still water resistant and nigh-indestructable that can both outshine AND outlast most other products on the market. You might also be able to flatten out the regulation curve a bit since you wouldn't be "holding something back" at the begining of the curve (because the user could just switch it into "high" if they felt they needed more lumens).
What do you think? Would it be plausable?
-Brian
Just hear me out...
-Brian
