witness
I just got my SC600 II L2 and I'm a little disappointed when I compare it to my original SC 600. When I switch from 500 to 750 lumens on my older SC600 the difference is obvious. When I compare 750 lumens (on the SC600) to 1100 lumens (on the new SC600 II L2) there is virtually no discernible difference. Not only does the older one seem almost the same but it throws a wider beam. This also makes me wonder if there is something wrong with my unit because while they are both supposed to have the exact same beam pattern (80 degrees with a 10 degree hot spot) the new model seems to have a significantly smaller hot spot (more like about 8 degrees if I was to guess). Any thoughts about this? I've been told that small 10-20% changes in lumen output is hard to detect but going from 750 to 1100 is an almost 50% increase and should be VERY obvious (not something one has to strain to discern).
