HKJ
[SIZE=+3]Basen 18350 700mAh BS186I (Black)[/SIZE]
Official specifications:
This is supposed to be a high current 18350 battery, it might not be perfect in that regard, but it has a lot of capacity.
The battery can deliver 5A, but not 10A. I wonder about the different in the two lowest current traces, there is a capacity different, but that difference disappears in the 0.5A to 5A range.
[SIZE=+3]Conclusion[/SIZE]
The battery has a good capacity and can deliver a lot of current, but being unprotected and with small differences in capacity it is best not to use it them series.
[SIZE=+3]Notes and links[/SIZE]
The batteries was supplied by Basen for a review.
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Comparison to other LiIon batteries
- Type: BS186I (High Drain)
- Capacity: 700mAh
- Voltage: 3.7V
- Style: Flat top
- Protected: No
- Max.discharge current: 10A
- Weight: 21±1g
- Size: Diameter: 18.00mm; Length: 34.73mm
