Hello - I need some advice on my XENO S3A 18650 flashlight.
I've had it for 2 years and its been great up till now. Its got fantastic color temperature (around 3000K), the battery lasts forever, and its super bright.
About 3 months ago it started flickering. Its gotten progressively worse and its basically unusable now. I think the problem may be in the switch. This is what I've tried:
- unscrew the endcap/switch and clean off the inside of the housing and switch contact area.
- unscrew the bezel and clean/inspect solder joints on the LED
- pulled on the springs to make sure theyre still springy and are getting good contact
I've noticed that i can get it to work a little if I screw the endcap on extra tight, but it still doesn't work well.
Any suggestions on what I should do next?
I really don't want to give up on it because its the smallest 18650 light I can find with a warm color temp LED. I use it for macro photography of insects and the warm light makes for better photos. The small size is nice because I can hold it between my ring and pinky fingers and hold a camera at the same time.
Thanks!
-Jordan
Thanks!
-Jordan
