Actually, I'm just an old retired fat guy, sitting around the house killing time by making myself obnoxious on forums like this. :thumbsup: But I was raised on a farm, and am familiar with trying to find things in the dark, hidden in bushes and weeds, and other nooks and crannies. I spent most of my working life as an IT wonk, working inside PC cases, under raised floors, over suspended ceilings, etc. You get the idea. If you've ever done your own plumbing in a crawl space or crawled around an unlit attic trying to find the top of the right wall to string some wire, you've got an idea of the kind of light one needs in confined spaces. Coleman used to make a really nice 6v lantern that had the typical incan head on the end, and a 6" fluorescent tube down the side that was great for that kind of stuff. And as far as long range, if they aren't disabled or almost dead, if they are more then 10-20 meters away you won't catch them anyway.
Since I seem to have made the description, let me give my recommendations. In the middle, a Nitecore EA41 in neutral white would work very well @ $70. It is not a high CRI but does do a reasonable job. If you want something a little smaller, with less throw (but still enough, IMO), look at the Lumens Factory Seraph 6 in 92+ CRI. Right now it is on sale for $40. For something bigger, the Nitecore TM06 will give a nice flood of light right in front of you, while still being able to see what that was at the other end of the football field. That would be at the high end as far as price goes, at $160 to $200. For really close 'at the end of your nose' type work the Terralux Nightstar 80 at 60 lumens and around 80+ CRI is not a bad buy @ $20. (If you like it in white, you can get two for $25 at Battery Junction).
Good luck on your quest. Let us know what you pick and how it turns out.
