dano
Wow...Streamlight has made a badass light. It's a beast. Overbuilt to say the least.
LED: XML2
Power: Streamlight 74175, same cell used in the Strion. Can also take an 18650 or two 123's. Note: the 18650 is not chargeable in the light.
Glass window!
Programmable (Streamlight tentap).
Recharged via USB, though it's slow. 14 hours on a normal USB 500mah charger.
My only dislike is that the aluminum shroud that covers the USB charging port should have been threaded, and not a press to close (an O-ring is used to hold the shroud in place.
LED: XML2
Glass window!
