Cabelas Alaskan Guide Light
ckali7
Guys, hoping someone can help with this. I have a Cabelas Alaskan Guide Light 1200LM that has been a decent light for a year or two until the battery bit the dust. Cabelas has discontinued the light and no longer offers parts for it. It till a little poking but I was able to get the battery out but have no way of knowing how to find a replacement. And, the old one seems to have some kind of circuit chip on the bottom. Battery seems slightly larger that 2 AA stacked on end.
Any ideas what this might be?
cland72
It appears to be two 17500 batteries stacked together. Do you have any CR123 batteries laying around? If so, put three of them in the light and see if it powers up.
Search
West Tn
From digging around Google it appears they originally used CR123's before being made rechargeable so OP should test like cland said and order some 17500s if you want to keep them rechargeable.
ckali7
Thanks guys, if it's just two 17500s what's the little circuit board on the bottom?
cland72
It is the protection circuit which does two things:
1. Prevents the battery from providing too much current if there is a short
2. Stops providing power after it drops below a preset voltage
LedTed
Britannia
That battery pack looks overwrapped to me. Looks like two batteries were conjoined into one. As you have already broken into the pack, may I suggest carefully removing the overwrap material and looking for model / part numbers?
ckali7
It's definitely two batteries wrapped into one. Each one looks to be about 2 1/2 inches long. Also Just realized that the charging plug was originally made into the battery module but was torn off when removed.
Parrot Quack
Magalia, CA
Are you trying to write that the OP is hosed as to battery replacement?
cland72
ckali7 is the OP, LOL.
ckali7, since it was an integrated battery pack I'm not sure about a viable replacement at this point. Maybe someone with more knowledge will chime in, but it might just be time to ditch this light and buy yourself something new, that will accept both standard rechargeables and lithium primaries.
Parrot Quack
Magalia, CA
The fewer comments that I get right, the less confusion I create.
"Do'h" :eek:
Well, there you have it OP, in this case, there's a good chance you're hosed. Maybe a nice brand new NiteCore TM16 will make you feel better about the loss. :naughty:
ckali7
Could I just toss the rechargeable components and go straight non-rechargeable? Or maybe have a new battery pack built somewhere like batteries plus??
ckali7
"Do'h" :eek:
Why do you say it's"hosed" ???
ckali7
Because it reads as if your light has had it guts ripped out and is beyond redemption.
No, the battery module was one single piece (composed of two batteries wrapped into one with the charger plug wrapped at the top) it was all made to slide right out of the housing....seems like someone could rebuild a custom battery pack with the charger...
texas cop
Texas
I have this light and the batteries are 18650's. In mine I just use Panasonics now when one cell died. You lose the plug in recharger but the cells were not good to begin with now off of 3400mah's I get twice the run time. Get a good charger like Nitecore a pair of good batteries and you'll still have a good light.
Parrot Quack
Magalia, CA
If you're looking for a project light, it reads as if you've found one.
Me? The most I'm willing to put myself through is ........... nothing.
In my opinion, I find there's nothing better than a good excuse to replace a light with a next generation light.
ckali7
Texas cop, how did you work around the reducer/holding sleeve that held the top of the battery in place? Did you just take it out or leave it in place?
ckali7
I guess what I mean is that if you eliminate the charger piece in the battery module there'd be a gap of about 1/2-3/4 of an inch. This would require a spacer of some kind.
texas cop
Texas
I used two protected cells the extra length and the springs worked. If I remember correctly the original cells and built in jack fit pretty tight length wise to begin with.
