I'm trying to decide which one to get. They seem very similar in specs. Anyone tried both?
I already own a Wizard pro, but I've had headlamp cravings for too long now
And I feel like I need a light that throws further. The HC30 seems to have roughly same throw as the H3 without sacrificing the wide spill?
Really any input on any of them would help! I will probably have to order before Monday to get it before Christmas.
I have both lights and I have done some simple testing.
I did one test running and another timelapse test with a camera, to check the runtime vs output. Both tests were done in cold weather, 1-2 degrees C. So that the lights would stay cold and stay in turbo mode. Batteries used was Panasonic NCR3400B
Runtime in turbo mode:
Nitecore will stay bright in turbo for 1h20min and than go to very low output.
Xtar will only stay on its brightest for 30-40 minutes, it will then reduce output to save battery. This way Xtar managed runtime of almost 3 hours. However not at full output. I would guess the output after 40 minutes to be 80% of full turbo output.
Tint:
Nitecore has more of a white/blue tint. And Xtar has a bit more greenish tint.
Headband/weight:
I like the headband of the Nitecore better, it is easier to take the light out of the headband. On the Xtar the light sits very hard in the rubber bands, and reading that som have broken theirs, I dont't think I will take mine out, and have it broken. Nitecore headband is maybe 10g lighter than Xtar headband. So total weight of Nitecore with headband is close to 20g lighter.
Heat:
-Indoors the Nitecore gets noticable hotter after a short time in turbo than the Xtar. I think this is because Nitecore is 10g lighter and most of this weight is saved on smaller cooling fins. However when running in cold weather, none of the lights got warm in turbo mode because of efficient cooling, and cold temperatures.
Conclusion:
Personally I prefer the tint of the Nitecore, and now that I know the runtime I will use the Nitecore when running in the dark. Mainly because i prefer full output for the duration of my run. For other uses where longer runtime is required, and when the battery status of the headlamp is not known the Xtar could be the better choice.
