Witterings
- Joined
- Dec 15, 2015
- Messages
- 282
My M1 arrived today, initially it wouldn't switch on at all, end cap on, off, on, off and the eventually it did work until I took the end cap off and went through the exact same 5x's process as before until it came on again.
Then it dims to 1/100th the amount of light it should be in all 3 modes .....same sequence as before (wiped the wire on the end cap and where the end cap screws into the torch) and all of a sudden worked a treat again.
This was fine for quite a few on and offs, the all of a sudden back to virtually no light at all, remove and refit end caps again and it's back to normal until next time I switch it on, dim, repeat previous process and again back to normal again.
This aside as trivial as it may be but the yellow safety sticker is only half stuck on / peeling up at one corner (was like it out of the box) and when the zoom is extended out the zoom part of the torch is quite "wobbly" especially if you compare it to my T7.2 ..... REALLY interested to hear if other M1 owners zooms feel the same when extended for narrow focus????
What do people reckon are the chances I've got a fake or is it just the Friday afternoon jobbie but when you're paying £40 for a torch you really don't expect as their quality control should be far higher!!!
