Of course, you might try emailing Henry. But reading his legacy user manuals reveals some discrepancies.
The manual for my EDC basic states in the cleaning & maintenance section that the standard battery compartment O-ring is:
"1mm X 22mm, 70 durometer Nitrile (Buna-N)"
but the same section for Novatacs states:
"1.5mm X 21.5mm 70 durometer Nitrile (Buna-N)"
So, not sure what these battery tubes actually use. I also have one of these closeouts, and took off the tailswitch to put on my EDC Basic 42. When I get home, I'll try to remember to measure the rings.
Update:
I measured the o-ring on my 17670 tube, and it's 1.05mm thick. The groove in the tube is 22.5 dia. so I believe the 1x22mm is the correct size for this setup. Also, my spare o-rings from Lighthound say 1x22mm.
Curious about the Novatac spec o-rings, and whether that has implications when using HDS parts with Novatac. I don't have any Novatac.
