Constant brightness, as a feature, is highly desired. Most flashlights, traditionally but also today, will begin dimming from their max brightness as soon as you turn them on, as the battery voltage drops, so do the lumens. If not specified, you can assume a light is not constant brightness. Without seeing a selfbuilt review on the light mentioned, I wouldn't hazard a guess. I do know from experience that the SC5w stays at 500lm until it steps down in a few minutes. After step down, the user can immediately put it back into turbo, and it is again 500lm until step down. It can handle at least several cycles like that on an eneloop pro before the voltage is too low for it to remain in regulation for 3 minutes, then the step down will occur in less than three minutes. But the light doesn't dim no matter how much voltage you have. It will even step down in lower modes once the voltage drops below 1V, but again, even at its dimmer level, the light will stay at a constant brightness and will not dim. As far as I have seen here and anywhere, the SC5 series are state of the art for flashlights, because of its max brightness, but also because of its constant brightness. Lights that dim with voltage drops do so sometimes slow enough that the user won't recognize the dimming until it gets very dim. When using rechargeable Li-ion this is problematic if the voltage drops much below 3V, as many are aware allowing the voltage to go low can damage the cell.
