Help! Mystery Surefire M series dropin ID
KennyC
Hello CPF!
So I'm going through my parts bin and found these.
Here's what I know:
-They fit in my M3T/M6 and work with 3 batteries. I'm afraid to try it in my M4 just in case they weren't meant to handle that much voltage.
-They look like some of the AW towers except these have knurling around the rim.
-There are no numbers/markings/logos anywhere on them
What do I have and what is the intended usage/input range?
Illum
Central Florida, USA
Thats a side emitter.... way back in the luxeon days. I'm afraid you might not be able to find much about them.
The left is either a Luxeon III or a Luxeon V emitter. Arc Mania [Mike Jorden] did a run of those in 2006
edit: Found the thread: http://www.candlepowerforums.com/vb...x-V-WX0S-Surefire-Tower-modules-are-available
The one on the right looks to be an SSC emitter. As best as I can tell, yclo made a run of those in 2008
edit: Found the thread: http://www.candlepowerforums.com/vb...pin-module-w-U-bin-SSC-for-Surefire-Turbohead
Further back, 2005 with pictures
there's your knurling: http://www.candlepowerforums.com/vb...om-Arc-mania&p=1122164&viewfull=1#post1122164
