I've had a few occurrences where one cell will be completely dead and the others are still at full capacity. For example the dead cell will be about 0.7 volts and the others in the same set are still at 1.6 volts. The cells can come from the same new package and installed into the device at the same time yet mysteriously it will go dead after a few months. I replace the batteries with all brand new ones at the same time. The devices are stored indoors climate controlled to 77 degrees constantly.
I've noticed this in my Fenix HL30 which takes two cells, the light output will dim significantly. I can have the batteries installed for a few months with an occasional 5 minute use a couple of times a month. Seems to be working fine then then the next time I turn it on I have no brightness control and the output is dim. When I check the battery voltages one is good and the other is bad.
Same thing happens in my minimag LED.
I have a garage parking sensor to tell me when to stop so I can clear the garage door and after a few months it will just stop working. check the batteries and the same thing, one cell is dead and the other 3 are still over 1.6 volts.
seems strange that in multiple devices one battery is draining so much faster then the others in the same set.
