Olight S2 replacement o ring?
oppositelok
Well after a bungled attempt to patina my Olight S2 Cu I managed to split the tail cap o ring too.
I have tried to search for answers but can't find then anywhere.
I don't suppose there is anywhere I can get original replacement o rings? Or does anyone know the size of the o ring?
As a temp fix I tried the o ring for an old mini mag light, while the diameter seems ok the thickness of the ring is to great to let it slid under the cap.
Any help appreciated
oppositelok
Unfortunately the Cu does not come with a spare o ring. It's packaged differently.
rookiedaddy
A Place Called HOME
you can try O-rings with CS (thickness) of 1mm and ID of 15-17mm. S2R is using 1mm (CS) x 15mm (ID). you can also ask Olight or their reseller for a couple of spare o-rings. :D
oppositelok
That's great, thank you for your help. I have emailed olight but they have not replied.
oppositelok
After an initial slow reply olight were in touch and there customer service has been great. Many thanks olight.
