silver_bacon
- Joined
- Jun 17, 2008
- Messages
- 85
Hello everyone,
I recently acquired a newer generation Bright Razor. The light uses 3 AA batteries. One of the first things I noticed was that the included documentation states the light is to be used only with alkaline batteries. In fact the light has a warning on it that says to use only Duracell MN1500 (alkaline) batteries. I contacted Brightstar directly to see why they advised this. They confirmed that the light is to be used only with alkaline batteries and should not be used with rechargeable batteries but when I asked why they so strongly recommended against using rechargeable batteries they simply repeated that I must use alkalines and stopped responding.
I'm just curious if anyone knows if there is a serious reason not to use the light with rechargeable batteries. I thought maybe the light might be too airtight for rechargeable batteries to ventilate properly but tail cap does not look very airtight. So I assume their reasoning is because the light is intrinsically safe and maybe they just haven't officially tested the light with rechargeable batteries. But I could very well be wrong. Anyone have any idea?
Thanks.
Thanks.
