Building a battery contact for a PR or PR-T head is not exactly easy. The early-run standard McLux heads included a battery contact assembly, but they won't work in a PR or PR-T without some modification. The problem seems to be that in the standard head there is a space between the top of the ecan and the "bulkhead" that the emitter rests on, which in the original design is where the converter board was to live. This space doesn't exist in the PR head as they are intended to be used with the ecan, in which the converter board itself doubles as the battery contact.
