What\'s the DIMMEST flashlight?
People keep asking what the brightest one is, but I don't remember anyone asking about the dimmest. I'd like something just bright enough to check my wristwatch with in total darkness, holding the light next to the watch.
What I've tried so far:
CMG Infinity: forget it, this thing lights up a whole room when you bounce it off the ceiling. Compared to what I want, it's practically a HID searchlight.
Arc4+ Second at level 16: dimmer than Infinity but still awfully bright, especially in the hot spot, which it easily casts across a room.
Countycomm coin cell light, white LED but underdriven with a single CR2032 3-volt cell: I like this, comparable total output to Arc4 level 16, but wider beam. Still I'd like something dimmer.
Arc4 "trick": set the lockout mode on the Arc4. Then press and hold the button. The light doesn't turn on, but draws a little current through the led as the microprocessor listens to the button to see if you're triple-clicking it. This makes just about the right amount of light, though very directional because of the Arc4 reflector. Much more problematically, 1) when you first press the button, you get two enormous blinding flashes that indicate that the light is in lockout mode; 2) you have to keep the button held down to remain in the dim mode after that, which is difficult; 3) You can cover up the bezel to suppress the initial two big flashes, but if you let go of the button for even an instant, you get blinded by another pair of flashes; 4) the amount of power the microprocessor uses fluctuates, so the light appears to flicker. So this scheme is sort of cute but not really that useful.
(haven't tried Rigel Systems Skylite, adjustable light, I'm told that at dimmest setting it's around 1/4 of an Arc AAA, measured current at 2.5 mA to two LED's. That sounds comparable to the Countycomm or Arc4, so too bright. But maybe it can be modded.
(haven't tried): PALight in "constant on, locator" setting. This maybe has some promise, though it has an optic that makes a big hot spot.
Anyway, it looks like it may be time for a home-made light with an LED and a volume control potentiometer (logarithmic taper). Other ideas?
