Aug 22, 2018 #1 A Adamn Newly Enlightened Joined Aug 22, 2018 Messages 1 Hi first time post I have an LED sign for a store that is flashing. I tested the output on the driver it is at 4vdc under load when it should be 12v. Do I have a faulty driver?
Aug 23, 2018 #2 M mercrazy Newly Enlightened Joined Jul 28, 2014 Messages 160 did you check supply voltage? bad connections will cause low voltage.
Feb 4, 2019 #3 I Incaorchid Newly Enlightened Joined Feb 3, 2019 Messages 9 Location Pacific Northwest What is the solution? Did you check voltage as recommended??
