I know we've discussed this before - but after measuring the current on one of my 5W mag mods, I decided to bring it up again.
With 1 ohm in a 6AA battery holder, fresh NiMHs would push a pleasant 1A through the VV0U emitter which I got back in February from the sandwich shoppe. At the time, I was surpised to find out that the Vf of this emitter was significantly lower than the U-bin that it was marked with (it was clearly a T-bin).
Now, with a fresh set of NiMH AAs, over 1.5A is pushed through the emitter /ubbthreads/images/graemlins/eek.gif. Same light, holder, resistor, etc. - just 3 months later.
Using my LM317 based current supply, I plotted the Vf curve. Here's the data for it (then and now):
<font class="small">Code:</font><hr /><pre>
VV0U Vf
I(ma) february now
0.1 4.94 4.89
30 5.67 5.47
130 6.04 5.77
310 6.34 6.00
620 6.64 6.24
1060 6.92 6.47
</pre><hr />
Nearly 0.5V drop at high currents. This emitter is well heatsinked, has never been severly overdriven nor overheated, and has only been run maybe 5 hours since then. I checked a V3T 5W light, and it's Vf is identical to what it was 6 months ago (about the same usage between the two).
I can't remember if we came up with a clear explanation or not for this Vf drop phenomenon - so here's some more data to ponder.
VV0U Vf
I(ma) february now
0.1 4.94 4.89
30 5.67 5.47
130 6.04 5.77
310 6.34 6.00
620 6.64 6.24
1060 6.92 6.47
</pre><hr />
