Re: Mag-Lite \"Donut\"
Actually, non of this will get rid of the doughnut in flood mode. The above suggestions will smooth out and improve the spot beam, but you will still have a dark void in the flood beam. However, it won't be as objectionable since the increased spill with partially fill in the void.
You can get a nice flood beam from the Mag, but it pretty much becomes a flood light since the changes needed ruin its ability to focus to a fine spot.
For a smooth(er) flood beam you can replace the lamp with a
frosted lamp (very nice beam with a bright central peak that still provides a bit of throw). If you carry a clear lamp in the tail you can switch between spot and flood.
You can rub the inside of the stock plastic lens with fine sandpaper or steel wool (this is also an easily reversable option).
You can spray the reflector with matte white paint. Matte silver will also work for a bit brighter, but not quite as even beam.
Aloha, Tim
