I have nothing against the concept of DRL's. I do, however, strongly object to the way they're being implemented and legislated (mandated).
I can offer my recent experience having purchased a new Volvo V70 R, which comes with HID's for regular lights and halogens for DRL's.
- There's only one light switch, which only has the traditional 3 positions 0-1-2, which leaves no way to turn off all the lights (including the DRL's). Sometimes you'll want them off if, for one example, you don't want people driving by to notice that your car is idling in your driveway.
- To meet the US DRL spec, Volvo took their Euro headlamp unit (which does not have DRL) removed the very bright separate high-beam lamp & reflector, and used that place for a lame low-wattage, dull-reflector, DRL. That left the US owners with only an HID lamp that's repositioned with a motor for low & highbeam use. It's not a good high beam at all. It's what the Euro unit uses as only the broad beam part of their broad+long lighting. Oh, and it uses a separate software control from the ECU so a US owner can't put a Euro lamp unit in the US car and have it work.
And losing the dedicated high beam for DRL is only part of the trouble with these lights -- Because there's only the HID's running on the high setting there's also the mandated self-leveling for HID's which for high beams results in not being able to see down an undulating road at all. (grrrr)
If there were a separate, dedicated DRL outside of the usual lamp assembly and a separate switch so I could turn the whole mess off or on however I choose then all would be well. Since it's being stuffed into the same assembly and I've also lost control of choosing how I want my lights to be on & set, I object.
I also object to its being mandated by law. A driver should know when it's prudent to have their lights on and act accordingly. Taking that decision out of their hands seems to me just a tacit approval that it's legally okay to be a braindead driver. ("Nothing wrong with this braindead driver; It's the manufacturer's fault for not hardwiring the headlamps on.") Sorta along the same lines of why I totally object to anti-cellphone laws and anti-reading-newspaper-while driving laws, etc.
