gadget_lover
Hi Folks,
I was impressed my UNNERV's Luminator. It's beautifully machined and VERY functional.
I was also impressed by the way he made a LOTC with a momentary pushbutton. It was machined so cleanly that I did not notice that it HAD a pushbutton.
Well, I was inspired.
I really liked what Patrick did for his momentary on tailcap. I copied the idea, but on a smaller scale. I made a momentary pushbutton for my ARC LSH-P twisty.
I started with a spare un-annodized twisty tailcap from ARC. I drilled a 1/2 inch hole in the end. I built a plunger that is 2/1000 of an inch smaller than the hole. The plunger touches the battery as well as the tailcap.
I added a small spring loaded plastic standoff to the center of the plunger to keep gravity from pushing the plunger against the battery, causing the light to turn on unexpectedly. The standoff presses against the battery. When you press on the plunger it is pushed into the hole in the center. As soon as I'm sure that I have finished changing the design the spring will be glued into the hole.
If the cap is screwed down all the way it acts just like the original.
I put in an o-ring groove only to find that I don't have any that are thin enough.
Here's the pictures;
After I made this picture I had to sand down the button to make it flush. I could have shimmed it from the other side with a drop of glue.
The button does not have to go down far.
On the left is the little nub that pushes the plunger away from the battery. It fits in the hole in center of the plunger with the little brown part towards the battery. There is no o-ring in the groove that I made for it.
Thanks for the idea, Patrick! /ubbthreads/images/graemlins/thumbsup.gif
I expect that I will need to add a spring to provide a consistant electrical path when an O-ring in installed.
The first prototype took only 45 minutes once I created a jig to hold the tailcap securely without scratching it.
Daniel
Daniel
