akula88
Ok -- you may say that I actually need a lantern... but I need a good-size light, preferrable surefire-based platform that could be used as a "lantern" or extended and continuous "bright-enough" light. /ubbthreads/images/graemlins/smile.gif
Most of my bright lights -- the 5W Stock-L4, 5W-TnC HLV, PRT-3W/DB917, KL1/3W/700ma, does suffer from excessive heat when run for 5-to-10 minutes. Yeah, SF are tactical lights, but I'm making them as general purpose for my usage /ubbthreads/images/graemlins/grinser2.gif
I am currently using the stock KL1 with Pila for this purpose. This is my bright enough light but tint is less than desirable by my current standards ( with all the other lights I REALLY could compare).
I once owned a KL3/PRT/3W/1200ma by Chop (Where is Chop?). My friend "bought" it away. Although I like the light, the PR hotspot seemed to be quite narrow for me for medium range and general illumination.
Can the 5-Watt be tamed to provide medium hotspot and a LOT OF sidespills?
I would like to run it with at least a Pila voltage (3.7) to 9volts. No single CR123 requirement.
Which Lux should I use -- 3W or 5W?
How do I regulate? -- voltage input would be 3.7v to 9v
My "power pack" -- SF-E2/BE3-series or SF-6P/9P-series
Environment -- mainly as indoor general lighting, at rare times as outdoor walk light.
Light Output -- "KL1 was near good enough, but tint is not desirable". Medium hotspot with a lot of sidespill.
Runtime -- 2 hours continuous, hanging or hand-carried; heat should be manageable. /ubbthreads/images/graemlins/blush.gif
Please post your suggestions and possible options...
