Re: What\'s the easiest Luxeon mod for a 2 or 3D Ma
[ QUOTE ]
GarageBoy said:
Oh, what size mag should I go for if I do the Space Needle mod? I've heard of people using 2xC mags and it'll still work? Also, how hard with it be to stick a BB in there? (My soldering skills are ok)
[/ QUOTE ]
You've got the hardest part of building an SN2 or equivalent covered already, since you can solder decently well. Believe it or not I wrote the OA4D Cookbook.. as my second mod. I'd never soldered ANYTHING in my life before I started modding lights!
The essential steps in a nutshell are remove the switch with an allen key, use a hacksaw or file to chop off the top of the switch, solder two wires to the positive and negative terminals. Drop the switch back into the housing and screw it into place. You'll have two wires sticking out the front.
Dab some epoxy onto the emitter and smack it onto the Hotlips, let it cure. Centering it is a cinch because of the raised center pedestal. Thread the two wires through the holes in the Hotlips and solder them to the Luxeon emitter. Slot Hotlips into housing.
You then have to saw off part of the reflector, and if you succeeded in sawing the switch (easy enough) you'll find it even easier. That's it, screw everything back together, light up and away you go.
The BB is a little tougher because you have to solder wires from the switch to the BB, then another set from the BB to the emitter, and it's quite a small PCB to work with but it shouldn't be anything you can't handle.
