Everled battery life in a 6D mag?
lasercrazy
NJ, USA
I have a 6D mag with 9ah nimh batteries in it and an everled. Anyone have any Idea as to how long it will last? /ubbthreads/images/graemlins/grin.gif
Niko
Herm, no idea, but I would be interested in knowing how long it lasts for. /ubbthreads/images/graemlins/poke2.gif
Short Circuit
If the Everled was kept cool to allow maximum power it should run just over 50 hours before a cell is damaged be reverse voltage. This is asumming the Everled is drawing 1 watt of power (buck mode is very efficent) and the Cells are full charged.
As the Everled gets hot, the power draw is reduced to keep the Everled from being damaged so the run time could be much greater.
[ QUOTE ]
[/ QUOTE ]
greg_in_canada
Saskatoon SK Canada
I don't recall the thread but didn't someone
mention that Everleds can die (prematurely) in 6 cell lights
because the fresh battery puts out more than 9 volts?
6-cell Nicad or Nimh would be okay since even at 1.4
volts per cell the battery voltage would be under 9V.
Greg
davidra
I was told they couldn't guarantee that any everled would survive 9 volts. I wanted to try one in a 2c 3x123 mod, but was told it would probably burn out. Kind of expensive to try it out, but if someone wants to, please let us know....
lasercrazy
NJ, USA
I guess 50 hours is good. /ubbthreads/images/graemlins/thinking.gif /ubbthreads/images/graemlins/grin.gif
Niko
It's gotta be longer than 50 hours, I get 40ish hours out of my 3D cell. Don't EverLEDs run for 50+ hours on 4D cells?
Glenn
PA
Re: davidra:
"I was told they couldn't guarantee that any everled would survive 9 volts. I wanted to try one in a 2c 3x123 mod, but was told it would probably burn out. Kind of expensive to try it out, but if someone wants to, please let us know...."
SAME HERE ! I would like know if it is practical.
Glenn
lasercrazy
NJ, USA
Hmm maybe I should have posted this in a different forum. /ubbthreads/images/graemlins/icon3.gif
greg_in_canada
Saskatoon SK Canada
Sorry for steering your question the wrong way.
I didn't notice that you said you were using nimh cells.
6 cells x 1.2 volts x 9ah = 64.8 watt-hours.
If the everled is consuming 1.2 watts then it should
run for 54 hours. At 1 watt it would run 64 hours.
One problem with running a regulated light from lots
of cells is that you won't notice when the first cell
goes dead. So you potentially could be running for quite
a while off 5 cells without noticing, while damaging the
6th one by reverse charging it.
Greg
