Picked one up (or two sort of) today. Its nice. Not sure its $270 nice though. The 1st one I got and brought home had a really sea-sick green tint on the 1st four levels so I took it back and got another one that was a lot better, although this one has a more pronounced doughnut than the sea-sick one.
The switching is a lot better on the production ones than the prototype I had once examined. The levels now move up or down in a more visually fluid manner. Previously they kinda "winked" btwn levels. Also the lowest level isn't necessarially all that low but its OK. The lowest level also has a high pitched "hum" like the L2.
There is a lot of "play" in the battery compartment so Pila fans will enjoy that also the black anodized finish looks great although it jumps from a glossy to flat depending on the part. Its no worse than how ha3 "natural" matches up.
The bezel down carry clip is an interesting change that sort of harkens back to SF's original Z26 lanyard ring that also once had a vestigual bend in it that was supposed to act like a clip like thing. The current clip is more serious and seems to work well. However a Z26 ring doesn't seem to work 'cause the switch is backed out enough to be locked out. So I'm not sure how lanyard attachement is supposed to work if you like that sort of thing. I suppose you could attach something to the skeletal clip but it would look and act sloppy.
All in all it seems nice if you can get one w/a good luxeon and have the $$.
In a practical sense, I'm not sure its any more useful than an L2 though.
