[ QUOTE ]
BBL said:
isn't non-conductive grease something i would not want on the threadings of the tailcap? after all it has to conduct electricity.
[/ QUOTE ]
Sometimes you don't want certain parts to conduct electricity. Also, the thread is so large, that only a part of it exposed will conduct electricity good enough.
If you pay attention to most flashlights (ie Mag) the lightbulb won't light untill you screw the bottom part all the way down, thats because the top part of the tube, not the thread, conduct the power.
And silicone grease does no damage to plastic parts, WD40 will corrode plastics.
I've used the grease on all of my flashlights and they work perfectly fine. I guess if you overdo it, and lube every concievable part, then it may interrrupt the electrical path.
