Theo
I was fooling around the other night and found that the xenon bulb for a Streamlight Twin-Task 1-L bulb drops into the socket of a Minim*g 2-AA. (You would have to drill out the reflector to make it fit in the bezel; there is plenty of clearance from the 'lens')
It was significantly brighter than the stock M*g bulb.
Question: Is this viable for use? Since both lights are for a nominal 3 volts, is the Streamlight bulb pulling more current? (I don't have a decent set of leads for my multimeter to test this). If so, how will this affect battery life?
As an aside, the bulb from a Streamlight TT 2-D light has the same brighness level on the Minim*g as the TT 1-L bulb, but it is too large to fit "under the hood" of the Minim*g.
Well, did the research. The MM bulb pulls 300 MA, the TT bulb 950 MA.
I guess that answers that. Run time will be significantly shorter, but it might be a viable option if you need the extra light, and use the Costco bulk packs of AA's (which are pretty good, btw).
Theo
Theo
