I found some 5mm white LED of 20,000 mcd on ebay(spec. in the latter part of this post).
I am planning to mod a Solitaire to the brightness somewhere brighter than a CMG Ultra. Due to the battery life and heat factors, I was thinking to underdrive a 1W/3W Luxeon at 150 mA or between 100 to 250 mA. Until I found these LED I had these questions:
How big the difference of brightness will be to drive this 5mm LED at its max IFP 80 mA(or a Nichia 5mm LED) and the 1W/3W Luxeon at 100/150 mA?
Compare this 5 mm LED with Nichia 5 mm LED, which has the better performance?
What I am thinking are:
A CMG Ultra is good enough to many people.
The CMG Ultra is made with a Nichia 5 mm driving at 65 mA(correct?).
A Solitaire which is modded to a 5 mm LED driving at 80 mA is much brighter and smaller than the Ultra(it would be better if the LED produces more mcd than the Nichia under same conditions).
With a 5 mm LED, we can easily mod the Solitaire and keep the candle mode and focus adjusting features which we can't find on an Ultra.
As refer to the Arc AAA, I guess the mod should have at least 3 hours of runtime.
If the above are true, I believe that this mod would be much better enough to more people.
An underdriven(100mA/150mA) Luxeon does not perform too much better than the 5 mm LED(need comments).
A 5 mm LED is much cheaper than the Luxeon (under $2 vs about $15).
It is a kind of waste if the Luxeon does not perform better than the 5 mm LED with the same driving current.
Compare to a 5 mm LED, a Luxeon is harder to fit into a Solitaire due to their form factors.
If these are correct, I should mod a Solitaire with a 5 mm LED instead of a Luxeon.
To make it simple, I am looking for a Solitaire mod solution regarding economic, battery life, heat and the easy to mod considerations. Any comments are welcome.
5 mm LED, 20,000 mcd spec.:
Absolute Maximum Ratings (Ta=25°C)
Item Symbol Absolute Maximum Unit
D.C. Forward Current
IF 20 mA
Peak Forward Current (1/10 Duty Cycle, 0.1ms Pulse Width) IFP 80 mA
Reverse Voltage VR 5 V
Power Dissipation PD 100 mW
Operation Temperature TOPR -25 ~ + 85 °C
Storage Temperature TSTG -40 ~ + 100 °C
Soldering Temperature TSLD 260°C for 5sec.
Initial Electrical / Optical Characteristics (Ta=25°C)
Item Symbol Condition Min. Typ. Max. Unit
Forward Voltage VF IF=20[mA] 3.0 - 3.8 V
Viewing Angle 2?1/2 - 20 - deg
Luminous Intensity
Rank A IV IF=20[mA] - 20,000 22,000 mcd
Rank B IV IF=20[mA] - 16,000 18,000 mcd
Rank C IV IF=20[mA] - 12,000 14,000 mcd
* Luminous Intensity Measurement Allowance is ± 10%.All LEDs
IF 20 mA
Luminous Intensity
