Re: Do NiMH\'s require a deep discharge conditioning?
Dave.
NO! DO NOT DEEP DISCHARGE A NIMH!
Discharging below .8 or .9 volts per cell is a recipe for disaster and can ruin NiMH cells.
Every 6 months or so, you can charge up your pack, then discharge to end of cycle (.9 volts/cell), then charge it up again, and this is all the maintenance your NiMH batteries will need. Other than that keep them charged up and don't store them for more than 6 months without giving them another charge.
Also, there are break-in cycles for new battery packs, which usually goes like this: trickle charge at .1C for 14-16 hours; discharge at .5C; then trickle charge again, or fast charge at up to 1C, then discharge at 1C, then charge by any method. This will "format" the new cells and break them in.
