EMPOWERTORCH
A torchaholic\'s pushbike lighting system
I've read quite a few threads on pushbikes customised with 10's of Nichia cyan LED's and LED's on the wheels frightening the living daylights out of non-torchaholics. What I intend to build is a practical self-powered LED lighting system for my nwly aquired pushbike. The main criterion is ruggedness...conventional pushbike lights cannot survive our appaling roads.
The system is to be powered either by a dynohub or a "bottle" dynamo charging either a small SLA or a set of Nicads or NiMH cells. Each light will have 8 high brightness LED's in it. I've chosen to use an "add-on car reversing light" as the headlight and an "add-on" rear fog light as the back light. These normally take a 21W filament bulb. I'm thinking of increasing the amount of light at the front by use of an additional set of cyan LED's along with the marker white LED's so the effect will give a light output resembling the Halford's VISON series headlight bulbs.
I've thoght about mounting the LED's through holes drilled in the lamp lenses; the c iurved surface will then allow you to have a nice beam spread.
The lighting system would be controlled via a motorbike-style handlebar-mounted thumbswitch.
What type of electrical output have bottle dynamos got... is it AC or DC? The AC (if it is AC) would be of a varying frequency depending on the speed of the bike. The Dyno Hub generator would generate a low frequency AC whilst the bottle dynamo with its high rotatiomnal speed will produce waveforms of several kHz.
To produc the charging circuit I would need first to convert the dynamo's AC into DC then incorporate some kind of regulator circuit to limit the voltage across the system. Some kind of regulator circuit needs to regulate the power so as to charge the battery up and not blow the LED's. Possibly the best and cheapest circuit limiter would be a zener diode. Alternatively I would use an IC regulator (LM317 comes to mnd from my distant dabblings with PSU electronics.....!
The charging circuit and the SLA/NiCd battery will be located in a diecast metal box attached to either the seat tube or slung under the cross bar.
What I should end up with is a self powered bike light system that unlike filament dynamo operated lights would be maintenance free, and he lights are still powered even when the bike is stationary or if the bottle dynamo is disengaged from the wheel.
If you have any circuit suggestions and advice please post to this thread... your collective torchaholic knowledge would be very useful.
Thanks
Matt (EMPOWERTORCH)
Thanks
Matt (EMPOWERTORCH)
