Our UCL® is AR coated, but most importantly, the term "UCL" is a name I'll give only to a lens that meets our transmission requirements.
A UCL® lens will transmit at least 98% - in some applications, more. It has a lot to do with the substrate. The glass under the AR is a low-iron glass that has VERY little tint. Sometimes referred to as "water-white" glass, it's lacking the green tint that normal soda-lime glass has.
We also need to make sure we're talking about AR as being an abbreviation for Anti-Reflective. There are some companies that market an AR coated polycarbonate or acrylic, but it usually means "abrasion resistant" in those cases. One such instance was the lens used in certain Arc lights. They were advertised as being AR coated, but it was "abrasion resistant."
Now, you can throw an AR coating on any type of glass, but to get the highest transmission levels, it has to be glass that has a high transmission rate to begin with.
