beakman
I'd like to try my hand at some of the popular incandescent mods that are being posted, and figured I'd start out easy with some KPR112 and KPR118 mods (while I work on acquiring parts for the more powerful mods). I'm familiar with the various options for using CR123s and AAs in 2 cell C and D Maglites, but I have a couple of questions:
1) Does anyone know what lumens the KPR112 and KPR118 are normally rated at? I've found the equation for re-rating lumens based on the overdrive/rated voltage ratio, and I've found the rated voltages for the KPR112 and 118, but I haven't been able to find the last part of the equation, the rated lumens for the bulbs.
2) What voltage are 3 CR123A's actually supplying? I know they're called 3 volt batteries, but have read that they actually start out a little higher (3.2 or 3.3v?), but will then sag under load to maybe something less than 3v? What voltage should I use per CR123A when trying to figure out if I'm overdriving a bulb too much, or in recalculating lumens using the overdrive/rated voltage equation?
3) Same question as above for multiple AAs. Do alkaline AAs really supply 1.5v each, and NiMH supply 1.2v each, when figuring overdrive tolerance and recalculating lumens?
I'm basically trying to get an idea of how powerful the KPR mods are compared to various stock flashlights and the more powerful mods. The lumens re-rating equation seems like a nice standard tool, and as an engineer I like calculating and tracking things in spreadsheets (but as a civil engineer who squeeked through my basic circuits class way back when, I'm still learning some of the terminology here /ubbthreads/images/graemlins/crazy.gif). Any help would be greatly appreciated. Thanks!
the beakman
the beakman
