By that I mean a light built from the ground up by modders, on a scale comparable to various modder LED light programs (Firefly, McLux, etc), i.e., starting with a custom machined body financed by 100-200 prepaid orders. It would solve all the stupid problems of Mag conversions and whatnot.
Fivemega's Fatmag is the only light I know that attempted something like this, but I don't know if it was ever sold as a complete TK light.
If you look at the current hotwire king, the Mag85 (based on a 3D Mag), it's a huge light with nine AA cells inside. That overdrives the 1185 bulb considerably so there's occasional instaflashes unless you let the cells rest for a while off the charger. And it's bigger than it needs to be. Mags are way oversized for the amount of stuff inside--several inches of the barrel are consumed by the switch. And the 3-to-D holders are somewhat longer than the AA cells they enclosed.
Look, by way of comparison, at the PT Surge, a bright (by normal standards) incan light with eight AA's that's less than half the size of the 9aa Mag85/MC85. A more powerful light might have to use a metal body and be a bit bigger, and should have charging contacts since it needs rechargeable cells anyway.
I guess I'm imagining a modder answer to the Tigerlight. It would use a custom machined body just a teensy bit bigger in diameter than a 2D Mag. It would have a small switch like the Surge. It would have charge contacts. It would use a stock Carley or similar reflector, to avoid the need to make a custom one. It would use a drop-in, shrink wrapped 8AA battery pack and have a WA G4 lamp holder so it could take a WA 01185 without melting. Overall size would be shorter than a 2C Mag, though thicker (maybe 1mm larger OD than a D Mag).
Another possible approach is a lantern-style configuration with a rectangular battery compartment. That could take one or two 7.2 volt camcorder battery packs with six 18650 lithium ion cells inside each pack. Those packs, and chargers for them, are available on Ebay pretty cheaply (search for NP-F960 battery).
Still another possibility is an 11 cell light (4+4+3 shrink wrapped NiMH pack) with an automotive bulb along the lines of the USL. The USL starts with a Mag 2D host, actually bores out the barrel to fit cells in, and replaces the switch to cram some cells around the switch assembly. Why not just start with a body made for the purpose. It will still look "stealth" to any non-flashaholic.
The amount of rigamorole needed to get the parts for a Mag85 together, and the number of people willing to do it, and the interest level in the USL, makes me think the time is right for a program like this.
