Hi LT, There is no perfect place to post an idea / question like you have - My suggestion was more based on the typical readers that post in LED vs the custom light area, not correct vs incorrect. Playing with LEDs, colors, and vision is very fun and intellectually interesting.
As you get more into it, you will quickly find that color vision is quite a bit more complex than the 2 D CIE curve or the pigment mixing charts we used as kids. There are some significant age / genetic / hunan factors that also affect how we see colors.
IMHO, these charts provide a useful simplistic way to tell an engineer how to "fool the eye under certain conditions", but really do not tell you how you actually see color and objects.
A good example of this is producing psuedo white light using blue / green + orange / red. If you draw the line through the CIE chart, you can make a binary system which passes through the white plankian, and the light produced is actually quite efficient due to the LED efficiencies at those points. Some colors come out fine / acceptable, others are completely missing.
Flashlights made from LEDs are a good example of balancing brightness, ability to see colors well, efficiency, and complexity. There isn't a "correct answer", just personal use / taste.
What modern "bulbs" have enabled, really for the first time, is the ability to have a choice in your lighting tools. There are some very interesting proposals on why 5 - 8 LED colors should be mixed to make better light. NIST has an interesting program (carried to the extreme of course) to callibrate spectrometers using MANY LEDs covering the human vision range. (I think it was every 3 - 5mn)
