Robocop
Moderator, *Mammoth Killer*
Ok I have spoke of this before however did not have pics.I now have pics and think most will like this mod as it is easy and pretty cool. You will need 2 AAA Dorcy tail caps as one has to have the switch removed to act as a bezel. This allows the Dorcy to be slimmer and a little shorter. I used a sanded down Solitaire reflector and an old Low Dome Lux I had laying around. I simply glued the lux to the factory board and removed the resistor for a little help with the output and it works great. I had to lenghten the slits inside the dorcy body where the board slides down for contact but not by much. This lets the board slide back a little to allow the bezel to screw down on the tail cap now acting as a bezel. I have carried this little mod often and it works every time and is pretty bright. Of course it is not water proof nor very solid but for the cost it is incredible...enjoy the pics.
[image]
[/image]
[image]
[/image]
[image]
[/image]
[image]
[/image]
[image]
[/image]
[image]
[/image]
[image]
[/image]
[image]
[/image]
[image]
[/image]
[image]
[/image]
[image]
[image]
[image]
[image]
[image]
[image]
[image]
[image]
[image]
[image]
